Андроид Плеера: Прошивка "200914_1539_R13" (Beta)
Сообщений в теме: 8
#1 rikki
rikki
  • PipPipPipPipPipPip
  • 327 сообщений
Отправлено 16 September 2020 - 12:55
Ченджлог:
- "Community" section in Dune Store ("Dune HD applications / Add..." menu),
  which provides access to applications and plugins developed by the
  community of users of Dune HD media players: changed the rules of showing
  this section in the menu in order to better match the currently available
  set of community plugins. This section is now shown in all CIS countries
  or when Russian UI language is used.
- Minor changes in the list of preinstalled applications.
- Minor other fixes and improvements.
- Also includes the following changes from 200810_1513_r13 firmware
  version.
- New feature: Realtek models: Added "Setup / Misc / Display / Brightness"
  setting which allows choosing the desired brightness of the front panel
  display, or switch off the display completely.
   - NOTE: This setting takes effect only after the player starts.
- Bugfix: Improved stability of firmware updates downloading in case of
  problems with Internet connection.
Dune HD Pro 4K II - "230602_0206_r21" + SD Card
Dune HD Magic 4K Plus - "230602_0206_r21" + SD Card
Dune HD Sky 4K Plus - "230217_0256_r21" [5°;13°;19°] + SSD
Dune HD Neo 4K Plus - "230217_0256_r21_r20"
Dune HD Solo 4K - "190919_0242_r11" + System Flash
#2 Demetrius
Отправлено 16 September 2020 - 13:04
Так плеера или плееры?
#3 RulerM
  • 8514 сообщений
Отправлено 16 September 2020 - 13:47
Ну в общем-то основное в этой прошивке - это Расширенный Дюнстор сделали доступным "из коробки" и предустановлен в Андроид части популярный HD Videobox
#4 Provizor
Provizor
  • 12 сообщений
  • Interests:Keenetic Ultra (KN-1810)
    Dune HD PRO VISION 4K SOLO
    Прошивка: Всегда последняя
    Dune HD Pro 4K, revision tv292b
    TV Sony KD-75XG9505 4K
    DENON AVR-2808
    DENON AVC-X3800H
Отправлено 17 September 2020 - 12:27
AFR в YOUTUBE не включили...
#5 usf922
usf922
  • 253 сообщений
  • Interests:Media-Sat-TV
Отправлено 28 September 2020 - 19:10
Лучше бы андроид посвежее накатили...
Ariva 4K UHD Combo S/S2/T2/C Android 5.1.1 (v05_01_2696)
Dune HD Sky 4K plus tv274a (230929_0206_r21 beta version)
Dune HD Neo 4k tv175e (220929_0206_r21 beta version)
Dune HD Solo 4K (190919-135-11)
Dune HD Smart D1(190919_135_R11)
Dune HD TV-301w (170721_0135_b9)
Dune HD TV-201C/T2 (170721_0135_b9)
Dune HD TV-102w (190919-135_b9)
Uclun Ustym 4K pro+(1.02.02)
Samsung UE40JU6500W 4К UHD
Openbox SX9 Combo
#6 Demetrius
Отправлено 28 September 2020 - 19:21
А какая разница какой там андроид? Егож всё равно не видно.
#7 apfelnase
apfelnase
  • 192 сообщений
Отправлено 29 September 2020 - 03:42
Видно, когда пытаешься установить Андроид приложение заточное под более высокое апи (например как в Андроид 7) и лицезреешь «ошибка парсера»
Dune HD Neo 4K T2 Plus (200914_1539_r13)
Dune HD SmartBox 4K Plus (200914_1539_r13)
И все «старые» модели ;-)
#8 Demetrius
Отправлено 29 September 2020 - 07:45
:D
Не пробовал, плееры и так вроде нормально работают. Вроде на SmartBox и RealBox разные андроиды, но этого не видно мне.
#9 yuganov
yuganov
  • 1171 сообщений
Отправлено 29 September 2020 - 13:20
андроид точно не будут обновлять, шкурка выделки не стоит. Конечно хочется пользователям, но смысла нет
Dune hd 101w
Dune hd 101w
Dune hd 102w
Dune hd Neo 4k plus
