Внимание!
Фото
Спецификация
OS: Android 6.0.1
Media processor: Amlogic S905X/L2 SoC
RAM: 1 GB
Flash memory: 8 GB
Wi-Fi: 802.11b/g/n: connect to your local network via air
Casing: plastic
Power supply: external
Power: DC 12V (1A), AC 100-240V
Dimensions (W x H x D): 101mm x 26mm x 101mm
Remote control: Dune HD Slim IR Remote
Коммутация
Media sources: External HDDs (USB), USB devices (USB flash drive, USB card reader, etc), built-in micro SD card slot, PC and NAS in local network (SMB, NFS, UPnP/DLNA, HTTP), other Internet and local network media sources
Micro SD card slot: conveniently use SD memory cards
2x USB 2.0 host: conveniently connect USB HDDs, USB flash drives, USB card readers, USB hubs and other USB devices
HDMI 2.0a output: output any video signal up to the most modern 4Kp60 HDR
A/V output (composite video + analog stereo audio)
Ethernet 10/100 Mbit/s: ensure good performance when connecting to your local network via cable
Power input: 12V DC
Поддерживаемые форматы
4K video playback: decode 4K video content in various popular formats including H.265 10-bit up to 4Kp60 HDR
4K video output: output 4K content up to 4Kp60 HDR with pixel-to-pixel precision to 4K TV
4K video formats: H.265 up to 4Kp60 HDR, H.265 10-bit up to 4Kp60 HDR, H.264 up to 4Kp30
HEVC: play video encoded using the latest H.265 codec. 2x picture quality increase over H.264
HDR support: play video in the newest HDR (High Dynamic Range) format. Superb picture contrast and details
10-bit color encoding: play video encoded using the newest 10-bit H.265 standard (1 billion of colors)
Video output modes: wide range of supported output resolutions and framerates up to 4Kp60
Video output framerate: automatic (according to the played content) and manual; 23.976 Hz support
Auto framerate: output video with original framerate to ensure absolute smooth playback for all kinds of content
True 24p output: ensure perfectly smooth playback of Hollywood movies due to full support for 24p (23.976) framerate
Advanced media player: play video in MKV and other modern video file formats, including top quality 4K and HD with very high bit rates (100 Mbit/s+)
Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264, H.265, H.265 10-bit; support for very high bitrate video up to 100 Mbit/s and higher
Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, ISO, folders
Video upscaling: high-quality upscaling of SD video content to 4K, Full HD 1080p and other HD resolutions
3D video: play popular 3D video formats, including Side-by-Side and Top-and-Bottom
HLS: ensure the best quality of Internet video using Apple HLS adaptive bitrate streaming protocol
DASH: get access to the newest Internet video services using MPEG-DASH adaptive bitrate streaming protocol
Hi-End music: play music files in various Hi-End audio formats: FLAC, Monkey's Audio APE, WAV/PCM, Super Audio CD, etc
Super Audio CD: play top quality SACD music files in various formats
Audio codecs: MPEG-1/2 layer I/II/III, AAC (PCM stereo), LPCM (PCM stereo), WMA, WMAPro, FLAC, multichannel FLAC, Vorbis, WavPack, APE (Monkey's Audio), ALAC (Apple lossless), SACD (Super Audio CD), AC3 (Dolby Digital), DTS
Audio file formats: MP3, MPA, M4A, AAC (PCM stereo), WAV, WMA, FLAC, Ogg/Vorbis, WavPack, APE (Monkey's Audio), ALAC (Apple lossless), SACD (Super Audio CD), AC3, DTS, DTS-WAV
Picture file formats: JPEG, PNG, BMP, GIF
Photo viewer functions: Slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write), exFAT (read-write), HFS/HFS+ (Mac OS Standard/Extended) (read-only), BTRFS (read-write)
Widevine DRM: Widevine DRM L1
Умный дом и домашняя автоматизация
IP control: integrate the media player with various Home Automation systems via network
Control4: integrate seamlessly into Smart Home installations based on Control4 technology via ready-to-use Control4 driver
Crestron: integrate seamlessly into Smart Home installations based on Crestron technology via ready-to-use Crestron driver
iOS and Android mobile apps: control the media player via applications for iOS/Android mobile devices
Комплектация
Dune HD SmartBox x1
Dune HD Slim IR Remote x1
Batteries AAA x2
Power supply 12V 1A x1
A/V cable 3.5mm-3RCA x1
HDMI cable x1
Quick installation guide x1
При настройке Deep Color выкл. весь контент выводится с 8-ю битами. Такая настройка рекомендована для ТВ с 8-ми битными матрицами (а также HDR Ready, матрицами, умеющими отображать HDR, но понижающими его до 8-ми бит).
Цитата ТП: "Выдается HDR, урезанный до 8 бит (при этом картинка остается HDR - с соответствующим HDR расширенным динамическим диапазоном яркости и цветовым пространством, но сигнал урезается с 10 бит до 8 бит)."
Для ТВ с матрицами, поддерживающими 10 бит и более рекомендуется выставлять Deep Color вкл.
При такой настройке сигнал выводиться с 12-ю битами цвета. По заявлению ТП Дюны на контент с 10-ю битами (HDR / HDR10+ / HLG) это не должно влиять негативно.
Цитата ТП: "Выдаваемый по HDMI сигнал в этом случае будет всегда 12 бит, независимо от того, что записано в файле.
Если в файле 8 бит или 10 бит, сигнал просто расширяется до 12 бит.
На качество картинки это как правило не влияет (а если влияет, то влияние малозначительное, и в какую сторону влияет - зависит от особенностей процессора в ТВ). Если нужен цвет более 8-бит и ТВ это поддерживает, то включить Deep Color."
«Настройка / Видео / Дополнительно / Режим RGB» может быть полезен для совместимости с некоторыми старыми моделями телевизоров.
AFR в андроиде.
На Смартбоксе это реализовано также, как и на плеерах Дюны с чипом Реалтек - работает внешний AFR, то есть единый механизм для андроид приложений, синхронизирующий частоту кадров экрана с частотой кадров видео вне зависимости от выставленных настроек в самих приложениях.
Подключение по HDMI
При настройке bitstream выводятся:
- DD, DTS - в многоканале 5.1
- DD+ (E-AC3) 5.1 (+Atmos) - в многоканале 5.1
- DD+ (E-AC3) 7.1 (+Atmos) - в многоканале 7.1
- DTS-HD MA 5.1 - ядро в многоканале 5.1
- DTS-HD MA 7.1 - ядро в многоканале 5.1
- Dolby TueHD 5.1 (+Atmos) - в многоканале 5.1
- Dolby TueHD 7.1 (+Atmos) - не выводится
- PCM / AAC (5.1 и 7.1) - выводится в PCM 2.0
При настройке PCM (декодирование) - все форматы выводятся в PCM 2.0
* В плеере Vimu, начиная с версии 9.06 появилась возможность преобразования многоканального звука в DD 5.1
Это позволяет выводить Dolby TrueHD в многоканале DD 5.1 (спасибо за информацию alex1963)
В отличии от плееров на чипе Реалтек плееры на чипах Амлоджик не умеют отдавать без передискретизации частоты 44.1, 88.2, 176.4 с обычных цифровых выходов, через внутренний и системный плеер всё выводится через звуковую подсистему андроида в 48 КГц.
Вывод без передискретизации возможен только через USB-Audio, к примеру, с использованием USB Audio Player или HiBy Music.
Профильная тема Usb-Dac Для Моделей На Android
Внимание! Системные настройки звука менять не требуется, это ничего не даёт, т.к. настройки звука в Dune Shell имеют приоритет над системными, достаточно смены значений в Настройки > Аудио.
Воспроизведение / Управление (Субтитры / Плейлист / Кнопки Enter и Play / Дисплей)
Плейлист
Кнопка Play
На сетевой папке запускает поочерёдное воспроизведение всех файлов, находящихся внутри данной папки.
На папке с музыкальными файлами запускает поочерёдное воспроизведение всех аудиотреков внутри данной папки.
На папке с фотофайлами запускает поочерёдный показ всех фото внутри данной папки (согласно параметрам, заданным в Настройки > Воспроизведение > Просмотр фото)
На IPTV-плагинах запускает трансляцию с места последней остановки, а также позволяет сократить кол-во нажатий для входа в плагин, выбора категории, канала и т.д.
На видеофайле (при выборе вида со списком), либо карточке фильма (при выборе вида с постерами) запускает немедленное воспроизведение данного файла, минуя карточку фильма с постером и информацией.
Работает только в Источниках (независимо от выбранного интерфейса и не работает на постерах в главном меню в Новом интерфейсе).
На плагине 101.ru запускает трансляцию последней перед выходом из плагина выбранной радиостанции, а также заметно сокращает кол-во нажатий для входа в плагин, выбора категории, выбора радиостанции.
Кнопка Enter
Настройки > Воспроизведение > Управление позволяет выбрать между Показом плейлиста / Показом главного меню при воспроизведении файлов, либо Показом главного меню / Показом ТВ-меню при просмотре IPTV.
На всех видах папок осуществяет вход в папку.
На всех видах файлов (аудио, видео, фото) запускает воспроизведение с одновременным созданием плейлиста (если плейлист задан в настройках)
Субтитры
TXT-Субтитры (полные и форсированные) управляются по PopUp > Субтитры > Настройки. На пультах с кнопкой Субтитры соответсвенно Субтитры > Настройки.
Для PGS субтитров данные настройки не действительны.
Жёлтая кнопка "С"
Нажатие жёлтой кнопки «С» при нахождении в левом меню в подразделе Моя Коллекция либо на карточке фильма (в новом интерфейсе) позволяет быстро перейти в пункт «Моя коллекция / Управление папками» для работы с папками МК.
Перемотка
Тест чтения
Кнопка Clear
В приложениях Android позволяет быстро удалить ненужные приложения
На файле позволяет быстро удалить ненужные файлы.
Reset / Меню Recovery
Кнопка Reset на данном плеере отсутствует. Для входа в меню Recovery необходимо зажать и во время подачи питания удерживать кнопку Включения плеера на верхней панели.
Сброс настроек / перепрошивка из Меню Рекавери:
Скачать актуальную прошивку на флешку (если будем прошивать).
1. Отключить плеер по питанию.
2. Нажать и удерживать кнопку включения на плеере.
3. Подать питание на плеер и дождаться появления меню System Recovery
4. Отпустить кнопку включения на плеере.
5а. Для прошивки выбрать пункт "Apply update from USB"
5б. Для сброса настроек выбрать "Wipe Data/ Factory Reset, подтвердить свои действия и перестартовать Reboot System Now.
Полезные утилиты
Включение 32-х ступенчатой регуляции громкости (работает до сброса настроек)
Отключение 32-х ступенчатой регуляции громкости (возврат к 16 ступеням)
Сохранение и восстановление сетевых папок в Источниках
dune_service_save_network_folders.dsf 707байт 0 Количество загрузок:
dune_service_load_network_folders.dsf 721байт 0 Количество загрузок:
Страница оф релизов (стабильных и бета) ОТА прошивок - https://dune-hd.com/...are/smartbox4k/
Страница "New GUI" - http://dune-hd.com/firmware/newgui/
Актуальная прошивка
230929_0206_r21 - dune_firmware_tv175l_230929_0206_r21.dff - бета ОТА прошивка с New GUI
Это небольшое обновление с небольшими улучшениями
- Dune Extra: добавлено больше API для подключаемых модулей IPTV и фильмов следующего поколения. Некоторые другие улучшения, связанные с Dune Extra.
- улучшена совместимость с некоторыми серверами SMB (например, с некоторыми маршрутизаторами ASUS).
- Фильмы: при просмотре информации об актёре максимальное количество отображаемых фильмов увеличено с 64 до 256.
- настройка таймера сна жесткого диска теперь имеет дополнительные параметры: 1, 3, 5 минут.
- настройка таймера сна теперь имеет дополнительную опцию: 20 минут.
- небольшие исправления в логике автоматической частоты кадров.
- обновлены некоторые переводы пользовательского интерфейса.
- некоторые другие внутренние изменения.
История прошивок
230606_0206_r21 - dune_firmware_tv175l_230606_0206_r21.dff - бета ОТА прошивка с New GUI
Исправлено: сетевое соединение Ethernet могло быть потеряно после перехода в режим ожидания в некоторых случаях.
Исправлено: некоторые аудиофайлы DTS CD воспроизводились с шумом вместо звука.
Исправлено: некоторые аудиофайлы DTS CD воспроизводились с перерывами.
Исправлено: кнопка ВВЕРХ на первом элементе плейлиста не позволяла перейти к последнему элементу.
Исправлено: в некоторых случаях режим масштабирования и соотношение сторон могли обрабатываться неправильно
Исправлено: в верхнем меню некоторые символы на некоторых языках ошибочно отображались как строчные, а не как прописные.
Исправлено: подключение дисков с определенными символами в метке тома могло привести к некоторым проблемам.
Исправлено: После первой настройки ТВ-приложения на Новый GUI пропадало отображение текущего элемента в GUI.
Исправлено: Отображение иконок групп телеканалов в режиме воспроизведения ТВ могло работать некорректно при большом количестве групп.
Исправлено: добавление телеканала в избранное во время воспроизведения ТВ могло некорректно обновлять информацию в главном меню.
Исправлено: Рамка курсора в некоторых случаях позиционировалась недостаточно точно (вокруг постеров и т.п.).
Исправлено: Качество постеров в Моей коллекции ухудшалось из-за ненужной ошибочной обработки.
Добавлено: Новая настройка (Моя коллекция - Хранилище данных - Качество постеров) позволяет загружать постеры еще лучшего качества для Моей коллекции. По умолчанию отключено, так как для хранения постеров требуется больше места и это может повлиять на производительность.
Улучшено: параметр «Настройки > Прочее > Управление питанием > Режим ожидания» переименован в «Отключение видеовыхода».
Обновлены/улучшены переводы пользовательского интерфейса для некоторых языков.
Для разработчиков: улучшены некоторые расширенные API, связанные с премиальной функцией Dune Extra.
Для разработчиков: улучшения для лучшей поддержки некоторых плагинов.
Внутренние изменения.
230223_1206_r20 - dune_firmware_tv175l_230223_1206_r20.dff - бета ОТА прошивка с New GUI
• Исправление: в некоторых случаях автоматическое переключение частоты кадров могло неправильно использоваться при воспроизведении видео в предпросмотре
• Исправление: в некоторых случаях чересстрочное видео могло ошибочно определяться как прогрессивное, что вызывало автоматическое переключение частоты кадров в неверный режим (например, на 25 Гц вместо 50 Гц).
• Исправление: когда приложение KODI устанавливалось автоматически (например, в качестве внешнего проигрывателя), его настройки звука могли быть установлены в неверные значения и зафиксированы на этих значениях (не позволяя пользователю изменять их).
Теперь пользователь имеет возможность изменять настройку параметров звука KODI.
• Исправление: процедура обновления прошивки пульта Bluetooth в некоторых случаях могла позволить пользователю установить несовместимую версию прошивки.
• Важные исправления в некоторых предустановленных приложениях.
221018_1640_r20 - dune_firmware_tv175l_221018_1640_r20.dff - бета ОТА прошивка с New GUI
Это небольшое обновление с важными исправлениями.
Более масштабные изменения и новые функции появятся в следующих обновлениях прошивки.
- Обновлен список предустановленных приложений в разных регионах.
- В некоторых случаях включение/выключение питания могло работать неправильно с некоторыми пультами дистанционного управления Bluetooth.
- Воспроизведение BD Lite в некоторых случаях не работало должным образом (регрессия появилась в r20).
220915_0010_r20 - dune_firmware_tv175l_220915_0010_r20.dff - бета ОТА прошивка с New GUI
- Исправлены ошибки в работе клиента/сервера SMB (регрессии появились в версии 220630_0727_r20).
- Улучшена поддержка изображений PNG в плагинах PHP и в некоторых других случаях.
220819_1253_r20 - dune_firmware_tv175l_220819_1253_r20.dff - бета ОТА прошивка с New GUI
• Исправлены ошибки в SMB-клиенте (регрессии появились в версии 220630_0727_r20).
• Исправлены ошибки в обработке тегов музыкальных файлов (регрессии появились в версии 220630_0727_r20).
• Исправлены ошибки в функции «Редактировать информацию о фильме» в файловом браузере.
• Исправлены ошибки в работе с настройками папок (порядок сортировки и режим просмотра).
220630_0727_r20 - dune_firmware_tv175l_220630_0727_r20.dff - бета ОТА прошивка с New GUI
- Новый интерфейс: Функция глобального поиска теперь ищет не только фильмы, но и персоны. Персоны (актёров) в результатах поиска можно просматривать аналогично фильмам.
- Новый интерфейс: Пользовательский интерфейс голосового поиска Dune: добавлена возможность переключения языка распознавания голоса между выбранным языком пользовательского интерфейса и английским. Полезно при поиске фильмов на английском языке, когда язык пользовательского интерфейса не английский.
- Новый интерфейс: Пользовательский интерфейс голосового поиска Dune: добавлена возможность запуска помощника Google из голосовой панели Dune.
- Новый интерфейс: Моя коллекция: Автоматическую переиндексацию теперь можно выполнять чаще, чем один раз в день (до одного раза в 4 часа).
- Новый интерфейс: Различные улучшения для индикации прогресса просмотра. Прогресс просмотра теперь отображается и для фильмов, не входящих в коллекцию фильмов.
- Новый интерфейс: Меню Последнее: улучшена обработка телепередач; некоторые другие улучшения.
- Новый интерфейс: Карточка фильма теперь содержит кнопку «Дополнительно..», когда есть более одного фильма для просмотра.
- Новый интерфейс: Восстановлена возможность поиска фильмов также при использовании старой версии графического интерфейса приложения «Моя коллекция».
- Новый интерфейс: Улучшенный предпросмотр видео. Это могло работать неправильно и в некоторых случаях неправильно вызывать функцию автоматической частоты кадров.
- Новый интерфейс: Улучшена обработка отсутствующего или плохого подключения к Интернету.
- Новый интерфейс: Улучшены возможности скрытия ненужных функций пользовательского интерфейса путем отключения встроенных плагинов в меню «Настройка/Прочее/Плагины».
- Новый интерфейс: Улучшено отображение длинных текстов.
- Новый интерфейс: Улучшена обработка случаев «Нет Интернета». Обеспечен постоянный доступ к Моей коллекции и другому локальному контенту без Интернета.
- Новый интерфейс: Повышение производительности и внутренние улучшения для взаимодействия с приложениями, которые встраивают свои данные в Новое интерфейс.
- Новый интерфейс: Множество других исправлений и внутренних улучшений в отдельных случаях (различные проблемы, обнаруженные во время внутреннего тестирования).
- Новый интерфейс: Внутренние изменения для следующих запланированных крупных улучшений (например, теги мультимедиа) (еще не готовы, появятся в следующих версиях).
- Добавлена специальная поддержка дисплеев с соотношением сторон 2,35:1 (например, проекторов с соотношением сторон 2,35:1). Его можно включить в меню «Настройка/Оформление/Дополнительно». Когда этот параметр включен, пользовательский интерфейс масштабируется, чтобы соответствовать области 2,35:1 (со специальной обработкой фона пользовательского интерфейса), и субтитры по умолчанию перемещаются в эту область.
- Добавлена новая функция родительского контроля: расписание блокировки (см. меню «Настройка/Прочее/Родительский контроль»). Позволяет блокировать доступ к медиаплееру в указанные периоды времени. В течение этих периодов времени доступ к медиаплееру можно только временно разблокировать с помощью родительского кода (автоматически блокируется снова при переходе в режим ожидания или через 10 минут бездействия без воспроизведения мультимедиа).
- Онлайн-субтитры: Улучшена обработка эпизодов сериалов.
- Онлайн-субтитры: Теперь можно искать на 3 языках: выбирать язык субтитров, на выбранном языке пользовательского интерфейса и английский.
- Онлайн-субтитры: Множество других улучшений и исправлений.
- Улучшена совместимость с протоколами SMB1/SMB2/SMB3 при просмотре и подключении общих ресурсов SMB в определенных окружениях.
- Улучшена автоматическая настройка доступных служб и предустановленных приложений в зависимости от Местоположения.
- Улучшена обработка настроек страны в меню «Местоположение» (теперь поддерживаются как коды стран, так и названия стран).
- В некоторых случаях улучшено определение частоты кадров видео.
- Воспроизведение музыки: Информация из листа CUE теперь имеет больший приоритет, чем информация из аудиофайла.
- Исправление: Музыкальный баннер мог некорректно отображаться в течение короткого времени при запуске воспроизведения видеофайла.
- Исправление: При воспроизведении видеофайлов фотофайлы, находящиеся в одном каталоге, могли неправильно отображаться в мобильном приложении Dune Control как обложки для воспроизводимого файла.
- ТВ-плагины: Кнопка PLAY на ТВ-плагине в меню «Избранное» теперь работает так же, как и в меню «Приложения» (можно использовать для быстрого запуска ТВ-воспроизведения).
- Воспроизведение на ТВ: Добавлена поддержка HLS-потоков типа «Event» (доступно при использовании движка воспроизведения «engine:1»), включая возможность паузы и смещения воспроизведения по времени.
- Добавлена правильная обработка внешних устройств хранения, отформатированных как хранилище Android. Ранее такие устройства ошибочно отображались в меню «Источники».
- Исправление: Текст на языках с написанием справа налево (например, на иврите) неправильно отображался в мобильном приложении Dune Control.
- Исправление: Переключение каналов IPTV через P- в некоторых случаях не работало.
- Исправление: Настройка смещения времени субтитров в некоторых случаях не работала.
- Исправление: Ярлыки для папок NFS в меню «Избранное» в некоторых случаях не работали (не было доступа к сетевым папкам).
- Исправление: При добавлении ярлыка фильма в меню «Избранное» в некоторых случаях могла теряться афиша фильма.
- Множество других исправлений и улучшений при воспроизведении определенных файлов и потоков (различные проблемы, обнаруженные во время внутреннего тестирования).
- Расширенные настройки автоматической частоты кадров с новой опцией «предпочитать удвоенную частоту кадров».
• При его использовании контент 25-30p воспроизводится в режимах 50-60p; в противном случае содержимое 25–30p воспроизводится в режимах 25–30p.
• Примечание: полезно только при использовании видеорежима 4K (режимы 25-30p поддерживаются для разрешения 4K на всех платформах).
- Исправление: Голосовые службы Google не обновлялись до более новой версии.
220317_0257_r20 - dune_firmware_tv175l_220317_0257_r20.dff - бета ОТА прошивка с New GUI
- Новый интерфейс: улучшена обработка прогресса просмотра и возобновления воспроизведения в различных случаях, особенно для сериалов.
- Новый интерфейс: добавлена команда "Показать в файловом браузере" в контекстном меню в различных случаях, когда отображается карточка фильма, а также рядом с кнопкой "Воспроизвести файл из локального источника"; позволяет быстро перейти от фильма к соответствующему месту в файловой системе.
- Новый интерфейс: Исправление: после остановки воспроизведения визуальные сбои (некоторые ранее выводимые функции) временно отображались на экране.
- Новый интерфейс: Исправление: Постер и другие изображения не отображались в некоторых случаях после некоторых проблем с подключением к интернету.
- Новый интерфейс: Исправление: папки «Моя коллекция», определенные как корень какой-либо сетевой папки могли работать неправильно.
- Новый интерфейс: Исправление: новая функция глобального поиска не работала должным образом в мобильном приложении.
- Новый интерфейс: Исправление: в некоторых случаях в меню «Избранное» мог отображаться неправильный макет графического интерфейса.
- Новый интерфейс: Исправление: настройка, отключающая эффекты анимации, в некоторых случаях не работала.
- Новый интерфейс: Улучшения внутренней производительности.
- Добавлена функция автоматического засыпания подключенных жестких дисков после бездействия. Это поддерживается как для жестких дисков USB, так и для жестких дисков SATA. Период бездействия можно установить с помощью новой настройки «Настройка / Прочее / Управление питанием / Автозасыпание HDD при неактивности». По умолчанию эта функция отключена.
- Исправление: при форматировании медиаплеерем жестких дисков большого объёма в exFAT, он мог быть недоступен на ПК с Windows.
- Исправление: определенные файлы / потоки без звуковой дорожки не воспроизводились.
- Исправление: в некоторых случаях воспроизведение могло зависать при остановке воспроизведения или переключении канала.
Дюна, сделала подарок всем, кто ждал замену ультрабюджетным TV-102
Причем, на моей памяти это в рублевой цене TV-102 во времена когда курс рубля к доллару был в районе 30.
Для 2019 года выглядит весьма вкусно - 3990 руб
Спецификации на оффсайте
http://www.dune.ru/c...iapleery_1/128/
От Neo 4K Plus отличается:
- Более простой пластиковый корпус
- 1 Гб ОЗУ
- Вайфай только 2.4 ГГц
- Более простой комплектный ИК пульт
- Нет Bluetooth
Набор отличий понятный и весомый, но и разница в цене в 2 раза.
Лично пока модель не пробовал, на следующей неделе потестирую.
Но неожиданностей не ждется - основа аппаратной и вся программная платформа полностью идентичны серии Neo.
Есть столь любимая многими поддержка DRM для IPTV.
Нет сомнений, что для IPTV и просмотра фильмов (за исключением меню в образах и рипов с потоком более 80-100 мбит/с с сети) в дюновской оболочке - все будет отлично.
В среде Андроид 1 Гб ОЗУ, конечно, фактор несколько ограничивающий активное применение, это стоит учитывать - по опыту с первыми пластиковыми Neo 4K тут все прогнозируемо.
