Ip-Управление Dune Control Для Линейки Android Плееров
  • Закрытая тема Тема закрыта
Сообщений в теме: 208
#1 TrippyCat
Отправлено 19 January 2019 - 13:44
Скачать Андроид приложение Dune Control  (Alpha Version)  и  альфа прошивку необходимую для работы Dune Control
http://dune-hd.com/dunecontrol/
Приложение для iOS devices:
Приложение для Android devices:
Приложение устанавливается на телефон/планшет и т.д.
Прошивки в архиве перед установкой архив надо распаковать!!!
Firmware (alpha version) for Dune HD media players:
190210_0252_r13
 изменения
Recent Changes
Improvements in the mobile app functionality in the latest update of APK and firmware:
Added support for folders with large number of items, all items can now be accessed (vis scroll) in all places (file browser, Movies, plugins, etc) (previously only first 36 items were accessible).
Added text editing support -- for all places in Dune UI where text can be entered/edited (dialogs, setup, file renaming, etc).
Added simple support for photo viewer: current picture, PLAY/PAUSE/STOP/PREV/NEXT buttons, swipe left/right on the current picture also does PREV/NEXT. Photo viewer status is shown in Navigator tab, Now Playing can be used to control background music playback.
Improved support for Full Blu-ray Menu playback mode: PLAY/PAUSE/STOP/PREV/NEXT buttons, indication of current playback position (time seek is not supported).
Improved support for Movie Information screens (Movies, Kartina.TV, plugins).
Added support for various screens, menus, dialogs which were not supported in the mobile app previously (Kartina.TV / Search, Kartina.TV / Start, Setup / Video, etc).
Fixed the problem with "tabs" view type in Dune UI skins.
Various other fixes and improvements in the mobile app.
Other improvements (not related to the mobile app) in the alpha firmware version:
Added support for CUEsheets (same as was available on Sigma platform).
Added support for chapters in MKV files (same as was available on Sigma platform).
1. Нет ограничения на 36 итемов.  Нормально скролится в плагинах (я проверил).
2. Добавлен ввод текста в поиске. В любое текстовое поле.
3. Добавлен просмотр фото.
4. Управление реботает в бд меню.
5. С пульта работают практически все менюшки настроек плагинов.
6. Заработали комбобоксы, теперь без проблем можно настраивать плагины.
Это не относится к управлению
7. CUE - не пробовал
8. чаптеры в mkv - работают
Версия для iOS будет доступна только через Apple App Store (после релиза). У версии для iOS на 100% точно такая же функциональность и выглядит как версия для Android.
Dune Control обладает следующими основными функциями:
  • Remote: используйте его как ИК-пульт дистанционного управления.
  • Навигатор: просматривайте и выбирайте мультимедийный контент с помощью Dune UI, отображаемого непосредственно на вашем мобильном устройстве. Доступ к локальным и сетевым источникам, Избранное, Последние, Моя коллекция, Фильмы, плагины Dune HD PHP и т. Д.
  • Меню, отображаемое на мобильном устройстве, отражает меню, отображаемое на экране телевизора.
  • Now Playing: просмотр информации о воспроизводимом в данный момент медиаконтенте, включая (при наличии) постер фильма, название фильма, музыкальную обложку, музыкальный альбом / исполнителя / информацию о дорожке. Управление воспроизведением (воспроизведение / пауза, остановка, предыдущая / следующая, позиция воспроизведения, громкость).
#2 kolor
kolor
  • 253 сообщений
Отправлено 19 January 2019 - 15:42
Спасибо. Этот плагин на Дюну, а как с Дюной связать смартфон?
Dune HD Sky 4K Plus Сист.флешка не требуется
прошивка: 191228_0342_r13
#3 yuganov
yuganov
  • 1171 сообщений
Отправлено 19 January 2019 - 15:43
это нужно установить на телефон. И в нём подключиться к dune
Dune hd 101w
Dune hd 101w
Dune hd 102w
Dune hd Neo 4k plus
#4 kolor
kolor
  • 253 сообщений
Отправлено 19 January 2019 - 15:53
Спасибо
#5 Brigadir
Brigadir
  • 5253 сообщений
Отправлено 19 January 2019 - 17:47
Отлично работает! Мне понравился поиск дюн в локалке - просто мгновенный, прекрасная реализация. Пока нашел один недостаток: если в браузере запустить просмотр фото, то страница браузера в приложении пуста, дальнейшее управление возможно только через вкладку пульта. Сделали хотя бы сообщение какое нить (для понимания происходящего) и кнопку возврата (отменяющую просмотр фото и возвращающую к навигации по папкам). А лучше отображать навигацию в папках на смартфоне и дальше, чтобы можно было прыгать по файлам, а сам контент смотреть на тв экране. Это чисто для удобства.
Ну и ждем-с куе (который сам по себе идиотский как формат навигации по трекам, но к сожалению пока распространенный).
Dune HD Pro 4K II (230929_0206_r21)
Dune HD Sky 4K Plus (221018_1640_r20)
Keenetic Giga (KN-1010)
(ЮMoney для благодарностей)
#6 alex1963
alex1963
  • 3655 сообщений
Отправлено 19 January 2019 - 20:12
Cue работает, но только в сторонних плеерах, например Usb Audio Player Pro, но с ним свои неудобства. Непонятно что за ограничение в 36 папок, дальше не отображается, как ходить по каталогу с музыкой?
Dune HD TV 303D, 190919_0242_r11, системный накопитель подключен.
Dune HD Neo 4K Plus, 230929_0206_r21,
Dune HD Pro 4K II, 240123_0207_r22,
Dune HD Pro Vision 4K Solo, 240301_0207_r22,
Boxy.
#7 Brigadir
Brigadir
  • 5253 сообщений
Отправлено 19 January 2019 - 20:37
Знаю, но речь идет про удаленное управление, и здесь актуален внутренний плеер, иначе не видно что играет и т.д.
#8 alex1963
alex1963
  • 3655 сообщений
Отправлено 19 January 2019 - 21:01
Удаленное управление в первую очередь актуально для проигрывания музыкальных файлов, чтобы не включать ТВ, а если видно только 36 папок, то вся актуальность вообще теряется, или у кого то каталоги полностью отображаются?
Boxy.
#9 Brigadir
Brigadir
  • 5253 сообщений
Отправлено 19 January 2019 - 21:21
Не пойму, при чем тут USB Audio Player, и как он относится к обсуждаемому здесь механизму удаленного управления?! Это ведь отдельное приложение, не относящееся к дюне прямо или косвенно...
#10 alex1963
alex1963
  • 3655 сообщений
Отправлено 19 January 2019 - 21:34
Я и говорю не про сторонний плеер, с ним все ясно, речь про IP управление, с помощью него захожу в сетевую папку, далее в папку с музыкой, далее папка жанр, в ней исполнители, так вот видно только 36 папок, а их гораздо больше, о том и писал.
Boxy.
#11 Brigadir
Brigadir
  • 5253 сообщений
Отправлено 19 January 2019 - 21:35
Ну да, косяк.
#12 RulerM
  • 8287 сообщений
Отправлено 19 January 2019 - 22:16
Ну на сейчас это даже не бета - альфа ).
Так что как раз максимально открыто для поправок и предложений.
#13 denik79
denik79
  • 4739 сообщений
  • Gender:Not Telling
Отправлено 19 January 2019 - 22:51
Понравился доступ к меню дюны с экрана телефона.В старом дюновском приложении для телефрна функционал побольше будет.
Клаву для андройда еще бы сюда,и чтоб экран дюны на телефон выводился.
#14 Kcaj5
Kcaj5
  • 490 сообщений
Отправлено 19 January 2019 - 23:05
Спасибо разработчикам за приложение!
Давно использую DUNE HD RC, хотя она уже и устарела и на смартфонах с высоким разрешением экрана выглядит немного нелепо, но у нее есть самая важная для меня функция - ввод текста на телефоне и передача его в поле ввода текста на Дюне.
В новой версии приложения эту функцию не нашел.
Если возможно, сделайте, пожалуйста.
Synology 412+(12TB) -> Zyxel Keenetic Ultra II -> D-Link DGS-1008D ->Dune Hd Pro 4K Il Rtd 1619, Dune Hd Pro 4K Il Rtd 1619\ Dune Sky 4K -> Onkyo Tx-NR828 -> QLED Samsung QE75Q70TAU 75" (2020)
#15 denik79
denik79
  • 4739 сообщений
Отправлено 19 January 2019 - 23:29
Полностью присоединяюсь, например в ютубе можно попасть в поиск,а вот написать там ничего нельзя, выглядит "криво" но понятно что это ещё альфа поэтому ждем доработок.
#16 denik79
denik79
  • 4739 сообщений
Отправлено 20 January 2019 - 00:18
Так же приложение работает через впн, т.е не обязательно подключение через  wi-fi. Можно юзать дюну откуда угодно.
#17 Rafael
Rafael
  • 24 сообщений
Отправлено 21 January 2019 - 08:50
Прикрутят клаву и будет топчик .
#18 Cinik
Cinik
  • 215 сообщений
Отправлено 23 January 2019 - 11:34
Я понимаю, что все это управляется через http запросы к дюне
А есть команда для запуская воспроизведения из папки, которая физически в сети находится, а не на дюне, в частности на внешнем НАС
Я дюной управляю из другого приложения, хотелось бы вывести кнопки для запуска воспроизведения из папок.
Ну или как-то с плейлистами побороться
Dune HD Neo 4K T2 Plus
#19 RulerM
  • 8287 сообщений
Отправлено 23 January 2019 - 12:07
У вас Дюна на Сигме, если подпись верна.
К ней это приложение и тема не относится.
#20 Demetrius
  • 21858 сообщений
Отправлено 23 January 2019 - 12:12
Не слышно, когда появится приложение для Duo 4k?
