Список изменений в прошивке впечатляет, и по мне так превосходит ожидания.
Например, поддержка образов и DTS в системном плеере - вообще не факт, что ждалась.
Version "180420_0153_r12" (BETA version)
- New feature: Playback of BD4K images is now supported in Dune HD internal player (both BDMV and BD ISO are supported). - New feature: Decoding of DTS audio tracks (stereo downmix) is now supported in Dune HD internal player. - New feature: Decoding of DTS HD HRA, DTS HD MA, DTS:X audio tracks (stereo downmix) is now supported in Dune HD internal player (for MKV, M2TS, BD images; DTS core is extracted and decoded). - New feature: Decoding of TrueHD and Atmos audio tracks (stereo downmix) is now supported in Dune HD internal player (for M2TS and BD images, not for MKV; DD core is extracted and decoded). - New feature: DD decoding quality is improved and it now supports Dolby DRC (Dynamic Range Control). (DRC mode can be adjusted via "Setup / System" menu.) - New feature: Remembering and restoring playback position is now supported in Dune HD internal player (same as on Sigma models). Remembered playback position is shown in Recent menu. - New feature: When starting file playback and there is a remembered playback position, a question is asked to resume playback from the remembered position or to start from the beginning. The new setting "Setup / Playback / Preferences / Resume playback" allows to control this behavior, with the following options: Yes, No, Ask user. The default is "Ask user". - New feature: REPEAT and SHUFFLE functions for playlists are now implemented (same as on Sigma models). - New feature: Subtitles visualization settings (vertical offset, color, font) are now remembered (same as on Sigma models). - New feature: Added setting "Setup / Misc / Encodings / Subtitles encoding" which allows to specify subtitles encoding (same as on Sigma models). - New feature: Sleep timer is now implemented (same as on Sigma models, works only when working with Dune HD GUI). By default it is disabled. It can be enabled via the new setting "Setup / Misc / Power manamenent / Sleep timer". - New feature: Added support for HFS+ (Mac OS X) partitions on storage devices with GPT partition table (in addition to previously supported MBR partition table). - New feature: Added support for storage devices with hybrid MBR/GPT partition table. - New feature: Added support for storage devices formatted without partition table. - Improvement: EXT2/EXT3/EXT4 and BTRS partitions on storage devices are now mounted more correctly (with full read-write permissions). - Improvement: Storage devices are now mounted more robustly, even if they were not correctly ejected last time. - Improvement: NFS browser now searches for NFS servers on all network interfaces when both Ethernet and Wi-Fi are enabled simultaneously. - Improvement: Automatic detection of subtitle encoding now works more correctly. - Improvement: In initial setup wizard, if the connected TV supports 4K, 4K resolution is now recommended by default. - Improvement: In initial setup wizard, the suggested by default timezone is now automatically detected based on GeoIP (when Internet is accessible). - Improvement: When Community source is enabled in Dune Store and there are a lot of applications to choose, applications are split by categories (as on Sigma models). - Improvement: "+" item in "Android applications" menu can now be removed (hidden) via "Delete" command in POP UP MENU, and then restored via "Restore hidden applications" command (i.e. same way as for other built-in applications). - Improvement: When UI Type 1 is used, "Android applications" section is now also available. - Improvement: When UI Type 2 is used, the "Applications" tab now has a proper title "Applications" (rather than "Dune HD Applications"). - Improvement: The hint about possibility to use "POP UP MENU" RC button is now shown on other main screens where it was not previously shown, but the button actually could be used. - Improvement: When performing "Reset Settings" action, a message is now shown while the system is handling it. - Improvement: Kartina.TV application includes now some new minor improvements. - Bugfix: In initial setup wizard, when booting w/o HDMI cable connected, the wizard crashed. - Bugfix: Playback crash could happen when stopping or finishing playback. - Bugfix: Starting audio playback immediately after player boot could cause playback crash. - Bugfix: Playback could hang when switching TV channels very fast. - Bugfix: Playback problems or crashes could happen in some cases after long use of the player or after a lot of switching between TV channels. - Bugfix: Subtitles could become not working till player reboot in some cases. - Bugfix: Playback of TS files and streams could hang in some cases when teletext subtitles substream is present in the stream. - Bugfix: Pressing NEXT RC button could cause playback crash. - Bugfix: Wrong information about the index of the current playlist element could be shown in INFO panel. - Bugfix: BD ISO with quotes in filename could not be played. - Bugfix: Plugin auto-resume and auto-start could not work in some cases when booting or when exiting standby mode. - Bugfix: Storage devices could not detected correctly when existing from standby mode in some cases. - Improvements for PHP plugins and PHP API: - New feature: For TV plugins which support TV archive (catchup), LEFT/RIGHT RC buttons can now be used to switch to archive mode and seek in the archive even in Live TV mode. For TV plugins which do not support archive, LEFT/RIGHT RC buttons are now correctly ignored in Live TV mode. - New feature: "PLAYBACK_STOP" action now supports the following additional parameters: "plugin_vod_stop_position", "plugin_vod_duration", "plugin_vod_start_tm", "plugin_vod_stop_tm", "plugin_vod_prebuffering_end_tm". - New feature: Added the possibility to use different fonts for the information shown in the right panel. The following new commands are now supported for "%ext%" syntax in "ViewItemParams::item_detailed_info": - "%ext%%fN%": use font size N (0..2) for the current text line. - "%ext%%f+%": increase font size for the current text line. - "%ext%%f-%": decrease font size for the current text line. - Improvement: In skins w/o glasses ("disable_glasses" set to "yes"), such as "Silver" or "Black" skins, a bit more space (30 pixels at the left and 30 pixels at the right) is now allocated to show useful information in the right panel. - Improvement: When loading images from HTTPS, the performance is now improved. - Improvement: When PHP plugin uses auto-resume functionality, "ip_address_required" setting is now enabled by default for this plugin. - Bugfix: "/tmp/run/ext_command.state" was not implemented; now it contains the information about current playback state (same as on Sigma models). - Bugfix: Playback timer did not work. - Bugfix: Saving/restoring playback position during auto-resume and setting initial playback position using PluginVodInfo::initial_position_ms did not work properly. - Bugfix: In "PLAYBACK_STOP" action, in rare cases, "plugin_vod_series_ndx" and "plugin_tv_channel_id" parameters could contain wrong information. - Bugfix: When switching to playlist item N, the next item (N+1) was actually wrongly used. - Bugfix: In TV OSD, crash could occur in some specific cases when trying to scroll through the list of TV channels. - Other minor improvements/fixes.
